could it be the cables are getting tangled and shifting your Y axis?
Seems to me a belt/Squareness of your machine.
Did you try to burn a big circle and a square, to test the acuracy of your squareness
say a 300x300 circle, if something wrong in your belts/Squareness, at the end of the circle the ends wont join.
Sorry, yes.
I meant mm/min.
Cables don’t appear to be tangled in any way.
I can try the 300x300 circle maybe tomorrow.
Most of the really inaccurate ones seem to be on the left side of the machine.
Everything on the right side is OK.
I would recomend recheking the squareness of the machine
I would unplug, move the Y gantry to the front most position
With an allen key unscrew gently the screw that tightens the syncronization rod
Wiggle it a little back and forward so it settles down, then press it back again the end.
Measure that left side and right side are square to the gantry
Screw again tightly the Syncronization rod. (Recheck others are also tight)
This seems to show what i suspected
Also the lines dont seem 100% straight
So you might have an uneven tension between left and right side of the machine belts
Do this - not so scientific - but the best way i have to test tension
Unplug machine from the USB and pwoer
Hold the front of the machine and lift it so its at a 45º Angle
The gantry should move smoothly without being touched to the back
LIft the back, and repeat
Then do the same test lifting Left side, and right side
The motion of the machine gantrys should be smooth, and rerquire no assistance what so ever
Newton laws of gravity are the key to help us define tension here.
If you notice any binding, pauses. then you need to readjust the tensions, untill the machine moves smootly
Also. do your gantry rollers have excentric nuts or just nylon spacers?
Another question before I run the test - should the plastic mount for the limit switch move?
It is quite wobbly. Tightening the screws has no effect - they don’t tighten.
Image below:
