Hey!
Does anyone know where I can get ahold of firmware for the Jiccoda L1?
I cant find it anywhere on the interwebs, and the SD card that came with the machine got corrupted.
Thanks in advance!!
Hey!
Thanks in advance!!
A bit of info:
β Recommended for new users
GRBL firmware.
β LaserGRBL and LightBurn - PC only
β Recommended for experienced users
- Note: The Mobile App, Custom PC Software and LaserGRBL and LightBurn are independent of each other.
If the engraver uses GRBL first, the LightBurn software can be refreshed without firmware. But to use the cell phone APP and custom PC software, you still need to refresh the firmware.
If you use the cell phone APP and custom PC software first, you need to refresh the firmware first, and then you want to use GRBL, LightBurn also need to refresh the firmware, and switch back and forth to use both need to refresh the firmware.
Limit switches are available for both firmware.
- Suggestion: If you donβt want to switch back and forth to refresh the firmware and find it troublesome, you can just use GRBL, LightBurn software.
You may contact customer service.
For us to help you more we need a photo of your laser controller/motherboard.
Thanks for the reply! PSD card came with two different firmware versions, unfortunately neither of them gives me control of the machine back. But the SD card was damaged and I had to use restore software to get a hold of the firmware, so Iβm hoping that it was just damaged during that process
