Just getting started with Eleksmaker
I used the software that came with it and it works ok.
Just set up with the wizard, but the movement controls are backwards. What should I do?
Please start by helping us to help you:
You’ve likely chosen the wrong origin - GRBL in LightBurn uses front / left as the origin. If you picked rear / right it would reverse everything. You can change this in the device settings.
