can a nano board be used with the k40 instead of the cohesion 3?
If you’re asking if LightBurn supports a Nano board for K40 then answer is no. You can get more information about supported boards and whatnot in the second half of this post.
I’m assuming you’re running on a 12V system. For a 5W laser the usual suspects would be:
Ortur LU2-4 - note that Ortur has recently transitioned to a 24V line of laser so they support both 12V and 24V modules. Make sure you look at the correct one.
NEJE A40630 - This was their flagship until relatively recently when they released their 10W module that has a dual-diode setup (A40640).
Sculpfun S9 module - This module boasts one of the smallest focus dots and longest in-focus beam.
It’s probab…
system
(system)
Closed
May 13, 2022, 9:33pm
3
