I guess I would have expected this to cause an issue with burn quality before showing up as a homing issue.
Grounding issues could potentially cause something like this but I would have assumed that the high voltage and low voltage side of these machines would be isolated.
When messing around in the machine, I suspect you may have also reconnected some other bad connection. Only a taught. but here’s hoping it stays working for a long time.
Thanks for uploading the M119. I find it odd that the default state is active for all the switches. Or maybe I’m not understanding Smoothieware behavior.
My K40 did the exact same thing. It worked perfectly with Whisperer but failed to home with Lightburn. I found the Y axis limit had a bad crimp on it, a slight tug on the wire showed a separated wire. I soldered the conecction and it homes perfectly ever since.
