Yeah, that looks dumb, all right.
These previous discussions may forestall killing yourself by making common (mis-)assumptions:
Did you miss that part about killing yourself?
Car sealant is not rated for the voltage (15KV) you are dealing with here. In fact, if it is black it may be full of carbon. You need high voltage RTV silicone sealant.
You also need to make a secure mechanical connection to the post, not just wrap it. That leads to an intermittent connection due to wire oxidation. Copper is a great conductor. Copper oxide is a great insulator..
Not enough time to do it right, but plenty of time to do it over?
Dear @ednisley and @MikeyH thank you for safety updates.
Regarding sealant I have read that it is needed to use 703 silicone or RTV car gasket sealant. Maybe I paid too less attention if I am using RTV sealant or any other type of car gasket sealant and it is my fault. Since I am having TC-703 which came with machine I will use only this material to ensure connection safety.
However, regarding soldering I have made some research before and I found that tight wire twisting
How do I connect wires when I replace my laser tube? - #3 by renegadeltd - Lasers - Maker Forums says:
Do not solder!
Forces on the post in the tube can crack it.
Don's Laser Things: K40 Laser Tube Specifications, Maintenance, Failure & Replacement says:
- Your anode wire may be twisted, screwed or soldered on the anode pin.
- Remove or re-terminate the old anode wire.
- Replace the anode wire in the same way it was connected, twist, solder or screw.
FSL also offers twisting without soldering, they just adding additional tape at 5:20 : https://www.youtube.com/watch?v=YBtMBGnp5pw
However back to topic. new Ruida mainboard came. And results are the same 1.9V⦠while PSU is connected.
Actually this was expected so there is 100% clear that both LPSs are faulty. Also I will use the new motherboard only because it could be that issues were caused by faulty old controler
I have ordered the new LPS (more expensive black one). However there is an open questinion why the new LPS broke after several seconds of engraving at the same way as old one. It looks like some component in the machine donāt like power spikes during engraving process and it leads to broken LPS. I am affraid that the third LPS could break in the same way too
Please help me to not screw the third LPS because it could be that root cause is still active:
Neither of those are rated for high-voltage insulation applications. Worse, if the gunk smells like vinegar while curing, the acetic acid it exudes will rot any nearby metallic objects.
If the high-voltage anode wiring was improperly insulated, the power supply arced to adjacent wires or the machine frame. Whether that killed the controller, the power supply, or other circuitry cannot be determined, but any and all of those seem plausible.
At this point Iāve lost track of what components / settings / connections are in play, so I will have nothing further to add.
