Help. All of a sudden, light burn will no longer fire the laser tube to cut.
I can pulse the laser, and its fine but lightburn will not trigger the tube while cutting. YES the output toggle is on. and yes I am verifying with an Ma Meter
Sounds like a hardware failure.
The complete system is digital, so the chances of this occurring are not very good.
I’d double check your tube for it’s resonating or TEM mode. If it’s not TEM00 then you need a new tube.
Lightburn and the controller generally work or not, but don’t fail in this manner.
