Lost of power on our Reci W6 tube?
If you have
  1. properly working tube
  2. aligned and clean optics
  3. proper focus
It will work, so one of these is having a problem.
A proper alignment should start at m1 (mirror 1) examining the beam quality from the source (tube). This should resonate in TEM00 mode or it never will align properly.
I cut targets out of watercolor paper so I can press fit them into the mirror holders.
The burn mark needs to be light enough to see the Gaussian power distribution curve across the beam. A picture of a hole is of little use. Generally lighter is more informative than darker.
Here is the curve … it should have more power in the center… you should be able to get a good cross section on your target.
The-distribution-Gaussian-of-laser-beam-profile-nb
We might not think of this as machining, but it is in the sense we are removing material by some type of tool… Both additive and substantive machining can do the job at a great variety of values, known as speed/feeds, however there is a small area of these values that works best with that tool and material. Meaning less energy, tool/machine wear and better results of the end product. I’m sure you’ve seen this.
For metal or man made materials cutting with spindles and bits you can compute the speeds/feeds for that item… When using naturally made materials and lasers it’s not so simple because we don’t have sufficient data on either the tool or the material. We can only control with accuracy the feed rate.
Speed usually relates to the tool spindle, with lasers it more like percent power and feed is how fast the material/head move by each other.
What I try to do is run at the maximum comfortable power at the fastest speed that will do the job.
This seems to give the best results for me and it what I commonly do.
I’d love to just be able to tell you the sweet spot, but alas I cannot. :cry:
Does any of this make sense?
The Reci is a good tube, a grade A Reci, if that’s what you have … I’d expect 5 years (10K hours) of commercial use before a failure… There are lots of variable here, but your symptoms look like the tube is going south.
Good luck
Hitting my head against a wall alignment issue
Mirror alignment. 80w CO2 laser red/Black Ruida controller
Trouble with cutting
CO2 Laser Funky Beam Angle
Laser losing power in certain spots
Boss LS-1420 / RDLV-V8.01.67 Z axis not moving up and down. will move on one direction only
K40 - Monport V2 for Lightburn - Power Settings
Issue Cutting with my 60w
150w OMtech, output power varies, lower than usual mA reading after 500hrs
EFR X4 100w and cutting 10mm acrylic
Divergent laser beam and imperfect cuts
Need Help Reviving My 80W Laser - X and Y Axis Won't Move
Getting a wide cut now
Power Issues in Bottom Right Corner
Inconsistent line scoring results
Horizontal bars left in images
CO2 power issue
Co2 60 watt laser cuts in material test but not when cutting a design in basswood
My laser tube produce double line
Suddenly not getting expected power out of laser
Upgraded Laser tube and Power supply. Material test did not go well. Do I need to update any settings in light burn?
Inconsistent engraving help!
Not Engraving 1st Timer
100watt co2 laser wpont fire at speeds any faster than 100mm/s all of a sudden. Anything slower its working. Any ideas?
Major loss of power but laser is working
OMTech 150W Laser has never fired under 20% and now 27%
6 year old 80W CO2 laser shows flickering when cutting, needs increased power
Normal current through ammeter, low laser output
Replacement Tube possible Power supply issue
My CO2 laser make weird moves, any solution?
Before I buy a new tube
Lasder will pulse but LightBurn not firing the laser
Life cycle of a laser tube
Could mirrors' alignment alter pulse spot size?
Laser is not cutting through materials like usual
Mirror Alignment issue, ring of death?!?!?!
Can't win, today: Now, it's alignment
Gifted 60w Chinese laser
A question regarding CO2 tube life
Cutting in High Humidity
Power issues 150w c02 chinese gray
Issue with laser going out of focus very quickly on material
