Laser Engraving on a Curved Surface
I’m interested in laser engraving on barrel stave and I’m wondering if Lightburn has the ability to use the Z-axis? I’m a novice at Lightburn, but I have run into a snag with the 3-D shape element.
Here is an example of what I was thinking:
Does Lightburn offer a solution to this (z-axis, focal length change, etc.)? If not, is there an alternative that I should use instead? I’m running a 7W JTech Laser on a Onefinity CNC.
Thanks in advance.
Also, here is an example of a finished product:
https://www.etsy.com/listing/1190029584/full-length-stave-coordinates-on-barrel
LightBurn is resolutely 2.5 D, without any notion of dynamically controlling the Z axis during a cut. It can set specific Z axis positions for a layer, but there’s no way to vary the Z axis across / along an engraved design like those staves.
That’s the trick: for slightly curved surfaces, a lens with a sufficiently long focal length will have enough depth of field to cover the whole design from a single Z axis position.
Some previous discussions may provide a starting point:
https://forum.lightburnsoftware.com/search?q=barrel%20stave
Hi.
Weclcome to the LB forum @thiggins .
That will be tricky to pull off with hobby equipment.
Not to mention with a 2.5D controlling software.
If Your One Finity CNC supports 3D engraving, IMO the easiest way to tackle this task would be to use some other software when engraving/marking curved objects.
Lightburn is truly a great software with a great team behind it, but there are lots of things it’s not capable of doing…yet :wink: .
In addition to those search hits @ednisley posted:
Not individual staves, but marking whole barrels was discussed in this:
thread.
As can be expected, that thread was derailed more than once, but there might be some nuggets of information that could be useful in Your case.
Regards,
Sam
:finland:
@thiggins, one possibility is to fabricate a custom roller mechanism to pass the barrel stave back and forth. With proper design, it could shuttle the stave back and forth while keeping the burn area at a fixed height. A NEMA 24 motor plugged into the Yaxis should have enough torque to move it. Then you could use Lightburn. :grinning:
No, you would need to use an auto focus. That is dependent on if your machine supports that. That is controlled by the laser and not LightBurn.
Thanks for all the great advice. I found an alternative solution by steam bending the barrel staves to be more flat. Since it is just g-code, I would have thought there might be a workaround using another piece of software to account for the changes in the z-axis.
