Laser head started doing silly stuff after a cut today Cant make it behave
OK I have an XTOOL D1 Pro with Extention and use a 40W head unit. Everything is up to date.
Just updated to LB 2.0
Checked firmware.
I even used it for a project shut it down and switched on my Fiber for a different project and then switched back and bang!!
In Current Position mode it does not return to the origin it tries to return to home.
At first I though it might be a COM selection issue but that wasn’t it.
The limit switches havent worked since I put the extentions on but I can adapt to that.
This sounds like an issue that multiple users are facing: Laser moves diagonal after every cut
Try to remove all saved laser devices and add them again. Then it should most likely work.
