Damonte
(Dave Girimonte)
January 24, 2023, 6:49pm
#1
Continuing the discussion from Laser issues on mirroring :
My limit switch button is broken so I’m getting a new main board, but the issue I have now when I get the chance to laser something the laser does not stop firing from letter to letter of what I have on the workspace I will include a picture of what I was trying to tell you thank you…
ColinW
(Colin Worobetz)
January 24, 2023, 6:57pm
#2
Usually this is related to the $30 setting in your controller. Please type ‘$$’ into the Console and copy+paste the result here.
Hi,
Ive just downloaded the trial version and made some “burning” tests. I’m very happy with my first results and with the software, but I could not find the solution for turning off the laser between shapes, the laser continues to work at the same power rate.
On my test I tried shapes with different order numbers, with the same order numbers, with different layers, or “Hello” word. But the same result as the attached photo, the laser is not turning off between cutting / drawing shapes.
What …
jkwilborn
(Jack Wilborn)
January 26, 2023, 1:05am
#3
Do you mean $32?
You might need to enable "Laser Mode" if you have GRBL 1.1f or later ($32=1)
I thought 30 and 31 are for the pwm generation ?
