I have recently installed the 40W NEJE on my Ortur Laser Master 2. It cuts great, but when it comes to the “Fill” with engraving, it is not neat-looking like my old Ortur module. I have tried changing engraving positions from 0 degrees horizontal, to 5 degrees (not shown), to 90 degrees vertical (not shown) and still every time I get these annoying 2-3 deep lines on either side of the fill. I have tried changing many things in the settings and nothing has changed it a bit. The rectangles are simple shape drawings in Lightburn and the Mustang is engraved using image format. They are engraved in a normal horizontal, side-to-side path from bottom to top. I have also tried using Ortur’s LaserGRBL, which I hate, and it still makes the lines there too. I know I have it wired in correctly or it likely would not function at all. I updated the Ortur firmware after I saw the lines appearing, still no difference. Maybe there is a firmware needed from NEJE for my Ortur motherboard? I will be contacting NEJE as well, if I hear something from them, I will update here.
