OLM 2Pro S1 stops after a couple minutes. Shows an alarm for flame and or movement. I have the alarm off. Anyone know where to get up to date firmware for the S1? Or any suggestions?
Can you show us the output from your console?
Type $$ into the console window and press enter, copy and paste the results into your reply.
$0=5.0
$1=100
$2=0
$3=2
$4=0
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=2
$15=0
$16=1
$17=0
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=4
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=0
$262=0
$263=30
$264=0
$265=100
$267=0
$100=80.000
$101=80.000
$102=400.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
I have also upgraded the laser to the LU2-10A
Looks like your flame and movement sensor is disabled, that should not present an issue.
Can you show us the error?
You could try enabling the sensor to the default settings.
$261=70
$262=500
[SC7A20:(25) Shock and Movement detected! Check TroubleShooting Section in User Manual.]
X8.9842Y7.9315
Ortur Laser Master 2 Pro S1 Ready!
OLF 172.
[MSG: Warning: Flame Sensor Disabled by User OverRide]
[MSG: Flame detector active,Ambient infrared value:0]
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
Job halted
Stream completed in 0:02
M5
OLF 172.
$X
error:9
G-code locked out during alarm or jog state.
[MSG:Caution: Unlocked]
ok
I just tried it and received the following
OLF 172.
$X
ok
Now this
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
ok
OLF 172.
$X
ok
After I entered the info I restarted the laser and Lightburn. Seems to be working fine. Thank you!!!
Those are some really strange parameters, especially $10 and $22.
Fore sure. 2047 is all 1’s binary, but 31 would have done the same thing.
Your chart has number options (4, 8, 16) mine does not have. Where can I get a copy like yours? ![]()
Its an older GRBL pocket guide but still good for most quick refernce
Good grief!!! I need to index my files, I already have that one.
Thanks!
