I downloaded the trial and was able to make 3 engravings. Now all of a sudden when I hit start the laser moves to position but never starts.
Ive tried multiple times and nothing, it has gone on for 20mins and when I stop it, I get a Job Halted msg.
Open the Console window in LightBurn.
You should see the wake-up or welcome message from xTool when it connects.
Start a job that worked previously to see if the problem is related to a new job or now extends to all jobs.
The Console should display a reason for stopping or an alarm or error message. If nothing is seen then you may be experiencing an equipment or communications failure.
Copy and paste some of the information from the Console window into a reply here. Attempt to capture information from about the time when the problematic behaviour occurs. Hopefully we can see it.
Waiting for connection…
ok
ok
ok
[XTool D1:ver 40.30.003.01 B9]
File imported in 11 milliseconds
Project file saved as grid Set.
Project loaded in 13 milliseconds
Starting stream
Layer C00 Pass 1 of 2
M8 N4
Guru Meditation Error: Core 1 panic’ed (IntegerDivideByZero). Exception was unhandled.
Core 1 register dump:
PC : 0x40085038 PS : 0x00060e31 A0 : 0x80085e66 A1 : 0x3ffc0090
A2 : 0x00002710 A3 : 0x00000000 A4 : 0x00000000 A5 : 0x00000000
A6 : 0x3ffbac04 A7 : 0x3ffb844c A8 : 0x8008502f A9 : 0x3ffc0070
A10 : 0x3ffbac04 A11 : 0x00000000 A12 : 0xfffffc01 A13 : 0x000003ff
A14 : 0x7ff00000 A15 : 0x3ff00000 SAR : 0x0000000e EXCCAUSE: 0x00000006
EXCVADDR: 0x00000000 LBEG : 0x400029ac LEND : 0x400029cb LCOUNT : 0x00000000
Core 1 was running in ISR context:
EPC1 : 0x40085038 EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x4008d7a4
ELF file SHA256: 0000000000000000
Backtrace: 0x40085038:0x3ffc0090 0x40085e63:0x3ffc00c0 0x40085efd:0x3ffc00e0 0x400866b9:0x3ffc0100 0x4008d019:0x3ffc0120 0x40081889:0x3ffb1f90 0x400e48e5:0x3ffb1fb0 0x400909e6:0x3ffb1fd0
Rebooting…
f~f~
Job halted
Stream completed in 0:56
ok
ok
start_home x
set_SGTHRS x (50)
enable x limit
x limit trigged
start_home y
set_SGTHRS y (50)
enable y limit
y limit trigged
MPos:0.000000,0.000000,0.000000
ok
MPos:0.000000,0.000000,0.000000,0.000000
Starting stream
Stream completed in 0:00
[MSG:Pgm End]
Starting stream
M8 N4
Backtrace: 0x40085038:0x3ffc0090 0x40085e63:0x3ffc00c0 0x40085efd:0x3ffc00e0 0x400866b9:0x3ffc0100 0x4008d019:0x3ffc0120 0x40081afc:0x3ffb1f70 0x400d2c32:0x3ffb1f90 0x400e48e5:0x3ffb1fb0 0x400909e6:0x3ffb1fd0
Rebooting…
f~f
Job halted
Stream completed in 1:08
ok
Another user had a very similar issue with the xTool D1 and solved it by getting a new computer. I suspect what that means is that there is an issue with the connection, port, or driver on the computer. Perhaps try a different USB port.
Or try modifying the baud rate for the connection. Did you setup the device with the .lbdev file from xTool?
Yes I used the file, I also tried switching ports
Another thought,
Open this job, click File, scroll down and click ‘Save GCode’
Change the file extension to .txt and drag and drop that file into a reply here.
I’d like to see where in the GCode the job stops.
I’m hopeful that I’ll see something with a setting of zero that upset the xTool.
