Laser not burning on Ortur Master 1 / M2190
Hello,
I’m recently new to laser engraving. I obtain an ortur laser but not 100% sure which model it is. It’s either the m210 or the master 1. When I connect to light burn it identifies the laser as Ortur (210x210). Aside from not knowing what model laser I have, the laser seems to work fine but when I run a program nothing is being engraved. I’ve had the power at 100% with cardboard and nothing burns. The laser and fan both run but it seems like the laser doesn’t have enough power. My computer has the latest version of light burn and my laser has the latest firmware and the S-value is at 1000. Thank you for any help you can provide.
Where is the s value you are referring to? Can you show the cut/layer window?
Here is the picture of my layer window. The S value is on the settings window
If you type in $$ at console, what is $30 set at?
It reads 1000
Can you copy and paste the settings here?
Waiting for connection…
ok
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master Model 210]
[OLF: 142]
[DATE:20:26:31 - Dec 16 2021]
[VER:1.1h.210324:]
[OPT:VNZHI,99,512]
Target buffer size found
ok
Homing
ok
$0=2.000
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=3
$11=0.050
$12=0.002
$13=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$30=1000
$31=0
$32=1
$33=500.000
$50=0
$51=0.000
$52=0.000
$100=80.000
$101=80.000
$102=80.000
$110=9000.000
$111=9000.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2500.000
$130=210.000
$131=210.000
$132=1.000
ok
