Laser not moving along y axis
I sent a file to cut a simple square, the machine did that. Then I sent another file to cut, and now the laser does not move along the Y axis nor does it hoem back to the top right corner as it should. Anyone?
Got yesterday a similar issue with version 1.0.3 after filling a traced image the y axis stopped always after around 50% of the job. Then only the x axis moved and the laser burned a straight line.
I did not check if it still persist with V1.0.4
yes, mine is also burning in a straight line as well along the x axis. Still trying to troubleshoot it
