Laser print is having scratch marks while moving over white space
I got scratch marks as laser is not getting completely turned off while traveling over white spaces. Any setting there to adjust in the software?
I am using diode laser 500mW in Creality Ender3 machine.
Minimum power is 0%. Maximum power is 100%.
Speed is 10mm/s at 100%power.
Speed over whitespace is 100mm/s.
(Got same scratch marks at lower speed over whitespaces also eg. 10mm/s)
Read through this and see if it applies to your situation.
If not, can you detail out how your situation is different?
