Laser stops cutting
On several occasions now, my laser has stopped cutting mid-job. I changed my USB settings to make sure it was not turning off and it still does it. It seems to do it closer to the end of a job. I have tried different designs and it still does it. It only does this during cutting, not filling.
Turning the verbose mode on for the console may generate some useful test data but you’ll have to push your engraver enough to generate the error. Rick shows how to do that that in post #5 here. Grbl 1.1f and image type engraving - #4 by hipik
If you get a comment about power supply the following may be worth review: Help, ortur master pro 2 loses power supply when laser is engaged
