Ok can anyone help me with this? Ortur lm 2
Usually, a mechanical issue. Check your mechanics: Guide to mechanical adjustments and maintenance
When you post a question, make it clear what you’re asking. It’s helpful to show a photo and explain what you wanted and what didn’t come out as expected…
I have no idea what the problem is or what I’m looking at in the photo…
What’s the problem? I guess you’re eyes are better than mine…
I suspected the outcome should have been a rectangular shape, and it looks squeezed on the right. But it can be intended as well… nobody knows…
This looks like the result of a mechanical issue. This article from our troubleshooting documentation might be able to help you.
Billie, those are some epic example pictures in that troubleshooting guide. I can’t even begin to imagine the amount of time it took to make them all so perfectly flawed!
Normally this is based as you said on a) loose shaft so one side of the Y is decoupled
b) frame is simply off square.
Thank you!!! I got on a roll with it and I just couldn’t stop, and Tyler tidied up all my errors, and then Jackie put it all together on the back end! A real team effort.
If you have any suggestions for it let me know!!
It’s part of a larger troubleshooting section we’ve been giving some love to in the docs.
