For what it’s worth I’m guessing what happened is that you set homing to include Z axis when you reverted settings. That was calling for Z axis to home which was never working since you don’t have an active Z on your laser.
I suggest you upgrade to the latest firmware so that this works correctly in LightBurn going forward.
The issue here is the firmware itself - Ortur made a version of the firmware for which the ‘normal’ state of the ‘homing’ setting is “43” instead of “1”. The spec for GRBL states that the $22 setting (homing enable) is a boolean, meaning it’s 0 or 1 to mean off or on, and when they changed it to include other settings, it meant that any software expecting the documented 0 or 1 behavior would no longer work correctly.
The $RST=* command resets all settings to their factory defaults, which works, but will also wipe any other settings if you’ve made changes. Entering $22=43 into the console will correct just the homing issue, or you can update your firmware to a newer version released by Ortur, as they’ve now corrected this.
I upgraded to lightburn 1.2.03 and since I did that everything on my machine has gone wrong I cannot do anything anymore, the coordinates are all off how do I go back to the last one I had before I updated it
I recently built grblHAL for some lasers with the JL1 board(STM32F103) and was surprised when I had LightBurn export the settings and not only did it change the $22 mask from “9” to “true” it also failed to create XML entries for grblHAL settings which weren’t part of grbl.
Is there a place in the forum we can discuss this and options for LightBurn to support new firmware’s grbl settings?
You could just create a new post in the GRBL topic.
LightBurn only knows to look for a specific set of settings, and it knows what format each of them is supposed to be. If you need to export / import settings that don’t follow the base GRBL spec (which states that $22 is a boolean), then you’d have to just capture the $$ output from the console, then run it back through as a command or macro.
