laser will connect to lightburn, and will home when told to. but when you try to fram the project and send project i get an error. tried playing with a few settings and searched for a fix but am stumpped…
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
Grab a screen shot of the Laser Window so we can see which Start From (coordinate system) and Job Origin you have selected.
Then Open the Console window and enter the following:
Copy and paste those reports back into a reply here.
I’ve seen position errors accumulate in some engravers and the most common cause of this is trying to recover after using a rotary attachment.
A current project that’s out of bounds or close to an edge (or has a tiny dot out of bounds) could throw this error but I haven’t seen it as often in this context.
