Laser wont fire but will move
Is there something wrong with these numbers in order for my laser not to fire?
ok
[PRODUCER:MKS DLC32]
[V2.20(8M.H35.20230626)]
[VER:1.1h.2023062602:]
[OPT:VPH,63,512]
Target buffer size found
[MSG:Using machine:MKS DLC32]
[MSG:Mode=STA:SSID=CresCommWiFi:Status=Connected:IP=192.168.88.40:MAC=FC-B4-67-86-96-E4]
ok
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=0
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=80.000
$101=100.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Not on a first glance, but there are odd values. Why do you have different steps/mm for x and y axis? Is this true?
You did not tell us what you did try.
1, Does the laser light up using the Fire button in the Move window?
2. Is this for one Lightburn file or all files?
3. Did it do anything strange, like intermittent, before quitting completely?
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=80.000
$101=100.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
$0=10
$1=25
$2=0
$3=1
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=1
$24=25.000
$25=1000.000
$26=250.000
$27=1.000
$28=1000.000
$30=1000.000
$31=0.000
$32=1
$38=0
$39=0
$40=100
$41=40
$42=1700
$43=5
$44=1
$45=1
$50=1
$100=80.000
$101=100.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=500.000
$121=500.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=400.000
$131=400.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
why will my laser not fire!!
Maybe because you are not answering the questions. Without answers, nobody can give advice.
