Hi everyone. I’ve been having problems with my X axis for a while now, and can’t figure out what is causing it. When cutting some large items the measurements are off. For example if i cut something that is 300mm on the X axis i get 301.5mm. I tried calibrating the axis a few times, and it helps for a short period of time but it just reverts back after a while. I did have a little accident when the laser head hit a piece of a cut plywood sticking out, which made the head go to a full stop. I noticed this happening a couple months after this happened. Maybe it is related, maybe not, i’m not sure. The controller is ruida 6445G, the laser path is aligned, and it is only for the X axis, the Y axis is fine.
Anyone has a clue why is this happening?
Thanks in advance.
