First thing to check is if the IP address of the bridge changed.
Easiest thing to do is go to Device Settings and click the Scan button.
Basically it re-finds your bridge if the IP has changed on you.
UGH! i should have known that, thank you!!
If it makes you feel better, I had to go find where it was first… I knew we had added it, I just couldn’t remember where. There’s a lot in LB - no worries
Hope that gets you sorted out!
