Light burn and RUIDA not syncing on the speed
My RUIDA and light burn are not syncing on speed.
You’ll need to provide way more information that this to get any assistance.
What do you mean?
Your question could be interpreted in a number of ways:
  • The Ruida is going faster or slower than you are asking it to
  • The Ruida is displaying different numbers than you see in LightBurn
If the numbers are different, are you in Inches in LightBurn, or using mm/minute for speed? The Ruida controller only displays mm/sec, so if you use inches that could do it.
There are also different “default” values shown on the Ruida controller screen that have nothing to do with cut settings. When you run a job, the numbers on the top half of the screen are just what you’ve set for jogging the laser, while the numbers in the bottom list are the ones for each cut setting being run.
