I have an Ortur Laser 2 20w. I use lasergrbl all of the time, but when I try light burn, it freezes and has alarm 2. This is frustrating because light burn has so much more to offer. I tried uninstalling and reinstalling. I’ve changing devices multiple times. I can’t seem to get it to work. I’ve attached a YouTube link to my issue. Hopefully, you all can give me some advice.
Hi, i’ve used LaserGRBL before and the software get‘s stuck very often. So i’ve changed to Lightburn with my Ortur Laser Master 2. Use the reset button one time on your Ortur board, the failure will disappear. In my case, it worked fine. Also check the cables, even USB and check if the wheels are free. Choose another picture, maybe the text was not right entered.
I got it fixed. I kept $10=0 and rebooted the machine a few times. Also reloaded the 1.34 frimware. New issue though now laser wont fire ugh. I put in a ticket with ortur since its not firing in GRBLlaser either might be a bad unit since all the wiring is correct.
Good luck to you on this issue.
Check the limit switch wiring too. I read that could be an issue
As long as you have the green bar showing ‘Busy’, you’ll get no response of any kind from LightBurn. You need to reset the connection to the controller when you get an alarm by right-clicking the ‘Devices’ button to reconnect.
After doing so, and re-homing, type $# in the console and press enter - what does it report back?
Well crap then…everything i saw said 1.34 needed to be installed.
Light burn and grbl never indicated a firmware version just said grbl 1.1 so I assumed Iwasnt up to date.
If you have a link to 1.37 id be ok restoring it.
I did $10=0 like 5 times and reset each time. So I dont know.
I actually have a support ticket going with gearbest which i bought it from. As since every other part is functiong correctly now it could be a hardware issue. Since i just got this on the 25th and the Fan turns on and it moves within parameters. Only thing not working is the laser.
connected, powered on and framed and tried to cut a square
I do not have a multi-meter handy at the moment.
also when I choose Get position it stays BUSY and the reset switch just powers it down
Aditionally, when you perform a cut, what are your settings (speed/power)
At the top of the laser head, do you have a red and blue led turning on, and fan on?
