This is a small release, mostly to fix the issues with GCode connectivity introduced in the laser version. A number of other small fixes and a feature or two are included as well.
Fixed connectivity issue with GCode devices
Fixed Text HSpace and VSpace glitching in Inch mode
Fixed a crash when importing an empty AI file with a missing metadata reference
Use last library save / load path for Load / Save of new libraries
Fixed occasional crash when starting a job using Beginner mode
Fixed numpad jogging for Linux
Enabled HW flow control for Smoothieware (should improve image throughput)
Auto device wizard asks for size if not found, turns off auto-home if homing disabled
Added Stucki dither mode (slightly faster than Jarvis, slightly crisper)
Fixed Marlin baud rate parsing for non-English locales
So, if I don’t experience any problems, no need to bother with this update (except for the dithering, but I do that in an image processing program, to be able to jump back and forth with other operations to fine tune image quality)?
The keypad jogging during text mode was an annoyance for some, and if you run Inch mode the text spacing controls were off. If you use a DSP, or had an existing 0.9.02 version that’s working for you, no you wouldn’t need to update.
