Good morning. I’m new so forgive me if I’ve posted this problem in the wrong location. Since updating to Lightburn 2.0.01, I have not been able to use the cut setting window that pops up after double clicking a layer within the cut/ layers menu. The problem is the window that open is to large and I cant click any of the buttons normally found at the bottom of this window. I can move the window left and right, however I can’t resize the window as you normally would. My curse will change to the arrow for resizing but nothing happens. Any ideas? This is on a Dell laptop running windows 11. Thanks
Same issue here.
- Window, reset to Default (Put all my tabs on one line)
- Edit, Settings, Display → Slide Tool Bar Icons and Font Size to the left.
My PC display is set for 150% and I think that is what caused everything to go huge.
I will be checking these settings when I return home. Ill let you know if it fixed the issue. Thank you
Thank you for reaching out @fbazzar. We recently announced that we have a fix for this and more:
If you are willing, we welcome your results. ![]()
I checked my windows settings and font sizes and they all appeared correct. I also attempted to resize the window in questions by pressing ALT+spacebar. I still couldn’t resize. Thank you for the advise and Idea though. Appreciate it.
@fbazzar, I do suggest checking out v2.0.02-RC-1, as we believe we have a fix for what you discribing. ![]()
I downloaded this version and no luck. I still can’t change the size of the cut setting editor window/ display. I reinstalled version 1.07.08 and all is good. I’ll have to run this for now to fulfill orders. Thank you for the assistance.
