Couple of LightBurn and Xtool D1
I have an issue with setting the origin. I have it all set up and burning stuff.
- The origin when set does not always set, Once I select where I want it I hit Clear Origin and then Set Origin. Just to check i hit Go to Origin and the Laser moves normally up a couple of mm
- If I stop the work and return origin it goes to a different location about 2 inches to the right of the original origin.
Thanks for any up you can give, have a good day
