I’m a LB newbie, have an Xtool S1, and have 2 questions so far.
- XCS has an auto measure function to find where the top of the material is. How does one trigger that in LB?
- Where does one select to Engrave, Score or Cut?
TIA - Richard
TIA - Richard
The S1 does this thing where it physically moves the laser to measure the height of the material to set the Z axis with a spring-loaded probe on the laser. XCS has a feature that launches this process to get the reading.
I was wondering if LB had a similar button to kick off this process.
Thanks!
Richard
Check the device in this topic you can make a macro or use the code in your device for direct control.
Just create a macro, with
M368
Whoa, really? Thanks!
This will be new and interesting. Lazy question: Is there a resource that amplifies LB macros and what can be done with them re: Xtool machines?
Good thing I have the S1. Thanks!
If you create an xTool device with the instructions @parsec linked above you don’t need to make the macro, The focus button in the move window sends the correct commands.
I just use this macro and several others I created. Sill looking for a macro to control the new Xtool Air Compress, as it only goes by default to high,
