LightBurn Bridge disconnects from my machine when camera is streaming in LB
Hello!
I’m having an issue, that’s newish to me, that when my camera is streaming through OBS and Lighburn is actively displaying the OBS cam stream, my Lightburn Bridge will not connect to the machine. If I kill OBS, the Bridge reconnects to the machine and lets me send files and control the laser as normal.
Any idea where my conflict might be? My IP to the machine is static and it’s using port 8080 for the stream.
TIA for any help!
Could it be a power supply issue? Possibly not providing enough current to properly power camera, wifi, and ethernet at the same time in addition to ambient power needs.
I ran a voltage check, via bash script. Here’s the return.
Am Over voltage?
What type of Pi are you running?
How long has the Pi been running when you ran the script? Has it been on continuously since streaming and attempting to connect to Laser?
Are you overclocking your Pi?
Can you check dmesg to see if you are getting any error messages?
Here’s the info!
Pi 4 (using official power supply)
Pi is always running. Months at this point. It’s been rebooted many times, though.
The stream is always running, yes.
The Pi is not overclocked, at least to my knowledge. I can check config and make sure.
Here’s what dmesg spits out. (sorry for the wall of text)
brcmfmac seems to have a lot of errors.
[ 3.016558] WARN::hcd_init_fiq:457: FIQ on core 1
[ 3.020868] WARN::hcd_init_fiq:458: FIQ ASM at 807c9984 length 36
[ 3.025284] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 3.029726] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.032030] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.034426] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 3.036740] Init: Port Power? op_state=1
[ 3.038957] Init: Power Port (0)
[ 3.041449] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 3.046056] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.048519] usb usb1: Product: DWC OTG Controller
[ 3.050875] usb usb1: Manufacturer: Linux 5.10.63-v7+ dwc_otg_hcd
[ 3.053265] usb usb1: SerialNumber: 3f980000.usb
[ 3.056464] hub 1-0:1.0: USB hub found
[ 3.058895] hub 1-0:1.0: 1 port detected
[ 3.062503] dwc_otg: FIQ enabled
[ 3.062516] dwc_otg: NAK holdoff enabled
[ 3.062527] dwc_otg: FIQ split-transaction FSM enabled
[ 3.062546] Module dwc_common_port init
[ 3.062886] usbcore: registered new interface driver usb-storage
[ 3.065560] mousedev: PS/2 mouse device common for all mice
[ 3.069165] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 3.074690] sdhci: Secure Digital Host Controller Interface driver
[ 3.077217] sdhci: Copyright(c) Pierre Ossman
[ 3.080274] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 3.083443] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 3.086267] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.090696] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.093709] hid: raw HID events driver (C) Jiri Kosina
[ 3.096478] usbcore: registered new interface driver usbhid
[ 3.099078] usbhid: USB HID core driver
[ 3.106946] Initializing XFRM netlink socket
[ 3.109557] NET: Registered protocol family 17
[ 3.112173] Key type dns_resolver registered
[ 3.115294] Registering SWP/SWPB emulation handler
[ 3.117835] registered taskstats version 1
[ 3.120168] Loading compiled-in X.509 certificates
[ 3.123320] Key type ._fscrypt registered
[ 3.125680] Key type .fscrypt registered
[ 3.128007] Key type fscrypt-provisioning registered
[ 3.142126] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 3.144680] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 3.151792] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 3.156042] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 3.158516] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 3.185910] Indeed it is in host mode hprt0 = 00021501
[ 3.249485] sdhost: log_buf @ (ptrval) (f4113000)
[ 3.288623] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.292635] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.296618] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.301783] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.304984] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.310189] of_cfs_init
[ 3.312553] of_cfs_init: OK
[ 3.328917] Waiting for root device PARTUUID=1e698895-02…
[ 3.364801] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.371021] mmc0: Problem switching card into high-speed mode!
[ 3.374972] mmc0: new SDHC card at address 0001
[ 3.378551] mmcblk0: mmc0:0001 SPCC 29.1 GiB
[ 3.383915] mmcblk0: p1 p2
[ 3.404506] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.406879] Indeed it is in host mode hprt0 = 00001101
[ 3.471594] mmc1: new high speed SDIO card at address 0001
[ 3.487997] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.492436] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.508833] devtmpfs: mounted
[ 3.518192] Freeing unused kernel memory: 1024K
[ 3.544926] Run /sbin/init as init process
[ 3.547358] with arguments:
[ 3.547369] /sbin/init
[ 3.547380] with environment:
[ 3.547391] HOME=/
[ 3.547402] TERM=linux
[ 3.654750] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.660052] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.663779] hub 1-1:1.0: USB hub found
[ 3.666725] hub 1-1:1.0: 4 ports detected
[ 3.984462] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 4.114755] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 4.120197] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.123931] hub 1-1.1:1.0: USB hub found
[ 4.126881] hub 1-1.1:1.0: 3 ports detected
[ 4.444455] usb 1-1.1.2: new high-speed USB device number 4 using dwc_otg
[ 4.670143] usb 1-1.1.2: New USB device found, idVendor=1bcf, idProduct=28c4, bcdDevice= 2.24
[ 4.675855] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.681480] usb 1-1.1.2: Product: WN-4K CAMERA
[ 4.684262] usb 1-1.1.2: Manufacturer: WN 210224
[ 4.686987] usb 1-1.1.2: SerialNumber: 01.00.00
[ 4.787647] systemd[1]: System time before build time, advancing clock.
[ 4.994520] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 5.013260] NET: Registered protocol family 10
[ 5.017494] Segment Routing with IPv6
[ 5.124969] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 5.130364] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.139787] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.160255] systemd[1]: Detected architecture arm.
[ 5.254418] systemd[1]: Set hostname to .
[ 5.408524] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.426413] libphy: lan78xx-mdiobus: probed
[ 5.455557] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 6.404547] systemd[1]: Configuration file /etc/systemd/system/lbwebdash.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.416038] systemd[1]: Configuration file /etc/systemd/system/lbrelay.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.424558] systemd[1]: Configuration file /etc/systemd/system/lbpistatus.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.436052] systemd[1]: Configuration file /etc/systemd/system/lbnetwork.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 6.586136] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.643039] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.647505] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 6.658250] random: systemd: uninitialized urandom read (16 bytes read)
[ 6.662355] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 6.670064] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 7.729926] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 7.835176] systemd-journald[114]: Received request to flush runtime journal from PID 1
[ 8.720245] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.722731] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 8.722760] [vc_sm_connected_init]: start
[ 8.723623] [vc_sm_connected_init]: installed successfully
[ 8.758433] mc: Linux media interface: v0.10
[ 8.853256] videodev: Linux video capture interface: v2.00
[ 8.955885] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.976205] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 9.002696] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.002704] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.003589] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.054579] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.056831] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.082566] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 9.368509] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 9.532384] uvcvideo: Found UVC 1.00 device WN-4K CAMERA (1bcf:28c4)
[ 9.535673] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 9.636684] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 9.636859] input: WN-4K CAMERA: WN-4K CAMERA as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/input/input0
[ 9.637714] usbcore: registered new interface driver uvcvideo
[ 9.637734] USB Video Class driver (1.1.1)
[ 9.648896] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.650567] usbcore: registered new interface driver brcmfmac
[ 9.685912] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 9.686487] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 9.686918] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 9.687326] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 9.687374] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 9.687921] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 9.687949] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 9.687972] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 9.687993] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 9.688014] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 9.688257] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 9.690517] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 9.690573] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 9.699212] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 9.699264] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 9.707354] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 9.707405] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 9.994704] usb 1-1.1.2: 3:1: cannot get freq at ep 0x86
[ 10.020532] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 10.020703] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 10.128766] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 10.188946] usb 1-1.1.2: 3:2: cannot get freq at ep 0x86
[ 10.191151] usb 1-1.1.2: 3:3: cannot set freq 16000 to ep 0x86
[ 10.192954] usb 1-1.1.2: 3:4: cannot set freq 22050 to ep 0x86
[ 10.194282] usb 1-1.1.2: 3:5: cannot set freq 24000 to ep 0x86
[ 10.388997] usb 1-1.1.2: 3:6: cannot get freq at ep 0x86
[ 10.391070] usb 1-1.1.2: 3:7: cannot set freq 44100 to ep 0x86
[ 10.392619] usb 1-1.1.2: 3:8: cannot set freq 48000 to ep 0x86
[ 10.432005] usb 1-1.1.2: Warning! Unlikely big volume range (=3328), cval->res is probably wrong.
[ 10.432033] usb 1-1.1.2: [7] FU [Mic Capture Volume] ch = 1, val = 768/4096/1
[ 10.444206] usbcore: registered new interface driver snd-usb-audio
[ 12.939864] random: crng init done
[ 12.939915] random: 7 urandom warning(s) missed due to ratelimiting
[ 13.277596] uart-pl011 3f201000.serial: no DMA platform data
[ 14.834520] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 16.971079] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.026473] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 17.549475] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 21.479599] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 23.033619] Bluetooth: Core ver 2.22
[ 23.033763] NET: Registered protocol family 31
[ 23.033774] Bluetooth: HCI device and connection manager initialized
[ 23.033816] Bluetooth: HCI socket layer initialized
[ 23.033836] Bluetooth: L2CAP socket layer initialized
[ 23.033868] Bluetooth: SCO socket layer initialized
[ 23.063250] Bluetooth: HCI UART driver ver 2.3
[ 23.063269] Bluetooth: HCI UART protocol H4 registered
[ 23.063367] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 23.063591] Bluetooth: HCI UART protocol Broadcom registered
[ 23.522801] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.522813] Bluetooth: BNEP filters: protocol multicast
[ 23.522830] Bluetooth: BNEP socket layer initialized
[ 27.339408] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 906.593844] TCP: request_sock_TCP: Possible SYN flooding on port 5005. Sending cookies. Check SNMP counters.
[ 4067.737124] mmc1: Timeout waiting for hardware interrupt.
[ 4067.737195] brcmfmac: mmc_submit_one: CMD53 sg block write failed -110
[ 4067.737209] brcmfmac: brcmf_sdio_txfail: sdio error, abort command and terminate frame
[ 4067.737390] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4067.737759] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.737771] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.737927] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.737937] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738087] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738097] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738245] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738256] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738404] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738414] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738562] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738573] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738720] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738730] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.738877] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.738998] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.739152] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.739162] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.740610] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.740621] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.740770] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.740781] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.740929] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.740939] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741087] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741097] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741246] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741256] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741404] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741415] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741562] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741573] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741720] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741730] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.741877] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.741888] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742146] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742156] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742291] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742301] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742434] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742445] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742577] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742587] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742719] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742730] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.742862] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
[ 4067.742873] brcmfmac: brcmf_sdio_rxfail: terminate frame
[ 4067.743114] brcmfmac: brcmf_sdio_hdparse: HW header checksum error
Running an apt get / upgrade to make sure I have the latest and greatest as well.
How long had the Pi been running when you ran the voltage test? The throttled=0x0 would indicate that it’s not experienced an under voltage scenario but only good info the Pi was on during the connection issue situation to see if it was a problem.
I don’t see anything obvious in the dmesg output. Again, only relevant if there was no recent reboot.
What are the IP addresses for wireless and ethernet on the Pi?
Are you able to ping the laser from the Pi while the Laser is not connected?
Also, if you have another power supply, might be worth swapping just to see if you get different behavior. Easy check.
I am running a small 5v fan off the gpio pins, since the pi was running a bit hot (it sits inside my Thunder Laser case, under the Ruida controller area.
Yeah, I can ping the pi and no packet loss.
IP: 10.0.0.38 for the Pi. eth0 is hooked to the Ruida controller, so no internet.
I would have thought that eth0 would still get an IP but I may be misunderstanding how Bridge is configured.
What is laser IP?
Are you able to ping the Laser from the Pi during the disconnect state? Trying to determine if you actually have network disconnect or something at a higher level not connecting.
I’m a little confused. Why do you have a camera on your Bridge and how are you using it with OBS? What exactly is the interface between the camera and OBS?
We do not currently support use of a camera on the Bridge Pi. We will eventually but we are not there just yet.
Please note that Bridge is designed as an appliance - we do not expect you to be doing anything with it other than what it was designed for. This includes running a camera from that Pi or upgrading the OS directly.
The laser is just snagging its info from the PI, but 10.0.3.3 is it’s IP.
@adammhaile There are a multitude of Bridge users doing exactly as I am. I got the camera setup instructions directly from this forum even, haha. Though it might not be supported, it currently works well. It’s a decent stop gap as we await the official support (which I was recently told is pushed further out until Galvo dev is finished) The OBS Virtual camera works well, barring this small issue I’m now having.
This definitely wasn’t happening until recently, so I’m not sure what I changed, or if something in a LB update affected something.
The laser’s IP should be static and configured in the controller as far as I know. I’m not aware of the laser being able to receive assignment from DHCP nor do I think the Bridge is configured for DHCPD. But could be wrong about this.
Are you able to ping the laser from Bridge during periods of “disconnect”?
The IP of the laser is static, correct. I manually entered it in via the bridge setup instructions. My pi’s IP is set to static as well in my router’s config. What I meant by info from the pi, is the info from LightBurn for controlling the laser itself. Not anything to do with networking. The pi is connected through ethernet to the Ruida, I would imagine is for the Bridge to communicate, as the Ruida doesn’t have wifi itself.
I can ping the laser via the pi @ 10.0.3.3 no problem. Even when LightBurn doesn’t see the Bridge, so it doesn’t seem to be anything on that side of things. I’m definitely at a loss of where the disconnect is happening.
Okay. Super interesting. In what way does the disconnect manifest to you? What does Bridge status show under the disconnect scenario? What do you see in LB? Does laser show as ready?
If I load LightBurn, without having OBS running, LightBurn will connect to the Bridge and send files and commands with zero issues. As soon as I open OBS, and the virtual cam starts to stream, and the stream updates in LightBurn, I no longer have access to the laser, and LightBurn reports it can’t find the Bridge.
So, when I can send, I see my relay log shows my PC’s IP and a port. Do you think I need to open those ports it’s using to send?
TL_send
TL_ports
I see I’m getting some LBBridge/dash.py errors, possibly?
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Fri May 27 19:17:14 2022
Traceback (most recent call last):
File “/boot/LBBridge/lbdash.py”, line 4, in
File “/boot/LBBridge/LBBridge/dash.py”, line 163, in run
File “/usr/lib/python3.7/curses/init.py”, line 94, in wrapper
return func(stdscr, *args, **kwds)
File “/boot/LBBridge/LBBridge/dash.py”, line 158, in main
File “/boot/LBBridge/LBBridge/dash.py”, line 74, in run
File “/boot/LBBridge/LBBridge/dash.py”, line 98, in update
File “/boot/LBBridge/LBBridge/dash.py”, line 148, in status_pi
File “/boot/LBBridge/LBBridge/dash.py”, line 85, in addval
_curses.error: addwstr() returned ERR
pi@lightburnbridge:~ $
Have you always run updates on the Bridge? If so, is it possible that you broke a dependency at some point?
Have you tried reflashing the Bridge and starting from scratch?
Yeah, I could re-image it and see. If so, I would not look forward to getting mjpg streamer working correctly again, hah. Also, I just found that my camera is not the correct one for my machine. I was meant to receive a 120deg lens, but they shipped an 85deg. That was another issue I was banging my head against for the last 6 months.
Maybe try on a spare SD card just to see if it resolves the issue. Then you could compare the 2 images to see what’s causing the issue.
