Hello, I would really like to get a Lightburn camera set up, but the PC I use for Lightburn is connected to my Ruida controller over ethernet in a different room. Is there any way to set up a camera with this configuration?
http://www.ipcamdriver.com will present an IP based camera as a USB device, and then if you use the ‘Default’ camera capture system in LightBurn, you can connect to that. Another option is to use a USB over Cat5 converter, and run up to a 150 foot cat5 cable from the laser to the PC.
