Hi, would it be possible to generate G code for LaserPecker 2 with it ?
I would need to see the kind of GCode the machine accepts to know if LightBurn has any compatible GCode profiles.
LaserPecker.txt (8 KB)
Take a look at attached sample gcode file.
That looks a lot like GRBL-M3 GCode, though the formatting is different, and it’s not clear why they have G4 P0 commands littered throughout - Those are pauses, but with zero pause time - technically that should do absolutely nothing, but since they’re included, I suspect they’re required and it’s not clear why.
You could try using the GRBL-M3 device profile in LightBurn and export GCode from that. It might work.
Ok, i will try it and let you know.
Link to same topic: LaserPrecker 2 compatible?
I read, not sure where, when I was looking at them a year ago, that although their software is proprietary, I understand it will load gcode, and will get it to the Laserpecker correctly…
I would assume if that’s true, you could just save the gcode and ship it to their software.
Didn’t follow up, but it might be a way to use some real software for that machine… Galvo…
Of course you’d have to find a victim, eh, a user that could try it…
There’s also the matter of the rotary option. I’m not sure how that integrates.
