I’m having some trouble. When I engrave lettering using the line item. Where you can switch from line,fill,or offset fill. the line setting it will join everything together. The laser doesn’t cut out in between like I’d like it to. It was working the way I’m trying to get it to at one time but I’m not sure what I switched to have constant power in the line mode. Same with drawing to of course. Thanks for any help
Hi Derek
Just to be sure about the issue can you post a screenshot of your design and explain what your trying to achieve using Line mode.
If you read this helpful guide on Asking for help you’ll get help much quicker.
You can also search in Lightburn Doc’s
Home - LightBurn Documentation
for information on using lightburn and also search previous post’s for topics that are similar.
