I have a Zbaity M37 Chinese laser and everything sort of works OK except for the "Move To Position X and Y coordinates in the Move Window.
I have set the machine size to 360mm x 360mm bed size and it homes to my 0 bottom left position well, I had to calibrate the X and Y axis to suit the M37 and it all works well now.
The issue is that when I set the Move to Position for X to 360mm and the Y to 360mm, the Y position travels at least another 50mm past the 360mm setting from my Home Position.
If I change the Y position to 300mm then it travels to the correct 350mm Y position, This issue happens in “Current Position,User Origin and Absolute Coords” the X position travels correctly no issues there.
Also if I click on Go To Origin the Laser always moves to about the 50mm position in the Y axis no matter whether I set the origin or clear and set the origin it always moves 50mm from my Home Position.
Hi berainlb, I ran the commands in consol and here are the results, I noticed in the ? command there is
a 53.000 in there and that seems to be the exact amount in millimeters that the laser moves to from the Home position when i press “Go to Origin”
Thanks berainlb, that fixed the offset issue. I thought it might be something like that, but I have no knowledge of the GRBL language, maybe I should read up on it.
Thanks again.
