Lightburn not burning, but does with LaserGRBL
can’t get the laseer to burn, but it does track. it burns with LaserGRBL without issue. What am i missing
Can you go to console window type in $$ then enter. Copy and paste output here.
Waiting for connection…
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 S2]
[OLF: 191]
[OLH: OLM_ESP_PRO_V1.2]
[SN: 9FFFECA125CC16B85FB563529A5F19C9]
[OLM:GENERAL]
[DATE:15:10:45 - Mar 13 2023]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[HOME:0.000,0.000,0.000:0]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
just ran that again and got this:
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 191]
[OLM:GENERAL]
ok
[TLO:0.000]
ok
Homing
ALARM:9
[MSG:Power Supply Problem:0V.Check TroubleShooting Section in User Manual]
ok
Ortur Laser Master 2 S2 Ready!
OLF:OLF 191.
OLH:OLM_ESP_PRO_V1.2.
OLM:GENERAL.
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Hi Wendy,
Thank you for the additional info. That helps us help you get back up and running!
I see a couple of things:
You have the latest Ortur firmware running on the laser :+1:
This means that the machine’s attempt to home failed because it didn’t locate a limit switch.
Click on the “ALARM:9” link above for detailed troubleshooting steps.
The docs page also links to the “Troubleshooting Mechanical Issues” page, which is always a good idea to check.
However! This is most likely the reason for the error:
If the power supply is defective, the controller would still be powered and connect over USB, but the motors won’t receive enough power to actually move.
(It’s still a mystery why it worked in LaserGRBL, but make sure the power supply is correctly plugged in and working.)
sorry, forgpt to plug in PSU, here is thr results with the power on
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[OLF: 191]
[OLM:GENERAL]
ok
[HOME:0.000,0.000,0.000:7]
[TLO:0.000]
ok
Homing
ok
$0=5.0
$1=100
$2=0
$3=3
$4=7
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=6
$15=0
$16=1
$17=4
$18=0
$19=0
$20=1
$21=1
$22=1
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=0
$46=0
$56=1.000
$57=1800.000
$58=405.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$100=80.000
$101=80.000
$102=2124.000
$110=10200.000
$111=10200.000
$112=600.000
$120=2200.000
$121=1800.000
$122=200.000
$130=390.000
$131=410.000
$132=100.000
$259=0
$260=70
$261=0
$262=400
$263=0
$264=0
$265=50
$266=100
$267=0
$268=0
$269=0
$270=5120
ok
Does laser fire in move window when you click it?
Do the lights on laser come on when laser should be active?
Do you have your S-Value Max set to 1000?
