I could not get it to work, but starting LightBurn just up from the terminal, that’s no problem for me. I’m not familiar enough with the Linux terminal at this time.
I also anticipate that the LightBurn team will implement your work at some point into LightBurn for Linux versions when the time comes.
Right now I’m just happy that everything is working fine - under Linux Mint.
@bernd.dk if that ‘.desktop’ file in your ~/Desktop directory did not create an icon on your desktop that runs when mouse clicked on then you can easily make your own. If you open your application menu and pick an application to drag/n/drop to the desktop that should make a copy of a file you can edit. The two key fields are the execute field and the icon field. The others are fluff IMO. Just make sure the line in the .desktop file for execution points to the LightBurnLibs/lightburn script with your full path. ie:
Exec=/home/dlarue/LightBurnLibs/lightburn
Icon=/home/dlarue/.local/share/LightBurn/LightBurn.png
