Again not sure if this is an operator error issue, but getting really frustrated with LB v1.0.0.4. Why is it when I use the “MOVE TO” function, (either X or Y), I enter value, 50mm, and the laser head goes off on a diagonal.
When X = 50mm & Y = 0mm it goes to X=180mm & Y=160mm
When Y = 50mm & X = 0mm it goes to X=110mm & Y=230mm.
Even after doing the RST command it stills does the same thing. When using the GRBL freeware, everything seems to work fine.
Really trying to make this work but seem to be fighting LB more than putting it to good use.
Settings:
$264=0
$100=80.000
$101=80.000
$102=80.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
WIN10
Ortur Laser Master Pro 2
Thank you for your post, but we need to see the entire list of firmware settings. Type $$ followed by Enter/Return into the console and post back all that gets spit back here.
thanks for the quick reply, here are the complete settings:
$0=5.0
$1=5
$2=0
$3=2
$4=0
$5=7
$6=1
$10=2047
$11=0.050
$12=0.002
$13=0
$14=2
$15=0
$16=1
$17=0
$18=0
$19=0
$20=1
$21=1
$22=43
$23=7
$24=600.000
$25=3000.000
$26=100
$27=3.000
$28=0.100
$29=0.0
$30=1000.
$31=0.
$32=1
$33=1000.000
$34=0.000
$35=0.000
$36=100.000
$37=0
$39=1
$40=1
$41=0
$42=1
$43=1
$44=3
$45=3
$46=0
$56=1.000
$57=1800.000
$58=395.000
$59=6000.000
$60=0
$61=0
$62=0
$63=3
$64=1
$65=0
$259=0
$260=70
$261=70
$262=290
$263=30
$264=0
$100=80.000
$101=80.000
$102=80.000
$110=10200.000
$111=10200.000
$112=1200.000
$120=2200.000
$121=1800.000
$122=2200.000
$130=400.000
$131=400.000
$132=50.000
ok
So any help from LB? Is this software, firmware or operator error I’m dealing with? Want to purchase license but need to get the kinks worked out. Would like to get a trial extension as well as I haven’t really been able to accomplish much with it.
Try this
$RSt=* in console
Wait for [MSg: Restoring defaults]
Imediatly tap reset on your motherboard then power up again
Press home button → go to Move pannel and press Get position
X0 Y0 reported?
Type $# in console; All lines show X0 Y0?
You should be good to go
seems to have helped. been able to run some samples. at the moment no longer have the offset.
does LB & Ortur get “confused” sometime?
here is what i got:
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G59.1:0.000,0.000,0.000]
[G59.2:0.000,0.000,0.000]
[G59.3:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G59.6:197.000,130.000,0.000]
[G92:197.000,130.000,0.000]
[HOME:0.000,0.000,0.000:7]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
thanks in advance.
Actually is a known firmware bug i am pushing engueneers to work asap on a fix
Currently G92 table offset, if set is non volatile (meaning it should clear on power off → power on) or soft restart
working hard to get this fixed in a few days
