LightBurn stopped launching
I had the latest version of LB and it started getting a little buggy. I deleted it, and downloaded the trial version which I assumed would see my license key and open the software. The LB icon just bounces. I went to look for answers and I see the perpetual license now on the website. I also thought I saw older versions of LB to download, but I can’t refind the link on the LB site.
Anyway, I can’t use LB. Did an OSX restart as well.
I have an MBP, M2 MAX chip, 32GB RAM, with Tahoe 26.5.1.
Do I have to buy the perpetual version of LB now to get my software to work?
Thoughts?
Hello Nelson
If you installed the latest version, you must allow 3-4 minutes of run time to the 1st launch as the files get translated by Rosetta2.
The consecutive launches should be normal.
Thanks.
Woke up this morning and it started right up.
Mine just stopped working too. On Windows, I can see boot screen for the app, it goes off and nothnig happens. I’ve been waiting for more than 5 minutes and still nothing. Running with Administrator privilges does nothing too. It was warking right after update to latest version and the only thing that have changed to my computer since the last time I’ve used this software was Nvidia update… help!
On windows is more a matter of possibly Redistributables C++
Please follow the steps described in this forum post.
So, I’ve updated C++ to the very latest version, and Lightburn 2.1.03 won’t start either. Checked Event Logs and found nothing connected to Lightburn. While still having the v1.7.08 update file on my computer I took the risk of installing it and Lightburn opened up normally, prompting that the newer version is available, but after installing v2.1.03 it doesn’t want to open - blue cricle next to mouse cursor flashes few times and nothing happens, it just shows up in task manager and dissapears (the Lightburn.exe)
Zrzut ekranu 2026-07-25 194457
And after removing it and installing again it still doe not start but I have this in Event Logs:
Nazwa dziennika:Application
Źródło: Application Error
Data: 25.07.2026 20:03:13
Identyfikator zdarzenia:1000
Kategoria zadania:Zdarzenia awarii aplikacji
Poziom: Błędy
Słowa kluczowe:
Użytkownik: PRACOWNIA\IwanStudio
Komputer: PRACOWNIA
Opis:
Nazwa aplikacji powodującej błąd: LightBurn.exe, wersja: 0.0.0.0, sygnatura czasowa: 0x6a43b8a2
Nazwa modułu powodującego błąd: LightBurn.exe, wersja: 0.0.0.0, sygnatura czasowa: 0x6a43b8a2
Kod wyjątku: 0xc0000005
Przesunięcie błędu: 0x00000000001e8f81
Identyfikator procesu błędu: 0x6778
Czas uruchomienia aplikacji powodującej błąd: 0x1DD1C5FDA9AF752
Faulting ścieżka aplikacji: C:\Program Files\LightBurn\LightBurn.exe
Faulting ścieżka modułu: C:\Program Files\LightBurn\LightBurn.exe
Report Id: 11257a26-b1c9-4945-9f89-06acd68ac269
Faulting pełna nazwa pakietu:
Faulting identyfikator aplikacji względnej dla pakietu:
Kod XML zdarzenia:
1000
0
2
100
0
0x8000000000000000
3037695
Application
PRACOWNIA
LightBurn.exe
0.0.0.0
6a43b8a2
LightBurn.exe
0.0.0.0
6a43b8a2
c0000005
00000000001e8f81
0x6778
0x1dd1c5fda9af752
I am running v2.1.03 on 3 different brands of laptops (Dell Win10, Acer and Lenovo Win11) and have no issues like this, suggesting it is a Windows issue on your machine.
Try reinstalling the C++ Redistributables again, and get it from the Microsoft website.
Uinstalled, installed again, updated all C++ installations found on my computer, runned sfc /scannow and DISM, still 2.1.03 wont’s start.
Lightburn support is going to ask anyhow, so can you make a screen capture (SHFT+WinKey+S) of Lightburn while it is trying to open?
You can try this:
Then send the Debug Log to support.
In Event Logs I can now see that Windows Error Reporting shows up right after Aplication Error when I try to launch Lightburn… And I found out what was the problem! Nvidia In-Game Overlay - it was craching the Lightburn, simply turned it off in Nvidia App settings and Lightburn opened up like it should be!
