LightBurn-v1.7.07 will not launch
I downloaded and ran LightBurn-v1.7.07 earlier this month. Now it will not launch.
What I’ve tried and failed thus far.
  • Reinstalled LightBurn-v1.7.07 version again.
  • Checked running applications under Task Manager thinking a previous was running and hung, which wasn’t the case.
  • Tried several suggestions from the forum which didn’t work (restart Windows 11 system, hold shift key when launching.) None worked.
  • I tried applying a recent patch I found in the forum. IDK the link for that patch seemed to just download the LightBurn-v1.7.07 all over again. This didn’t work either.
Curious, other than this forum, how do you contact support? Particularly when the application doesn’t run.
Update: I uninstalled the Lightburn 1.7.07 entirely from system. Disabled a whole bunch of startup items (They likely had nothing to do with problem but?), restarted, installed the previous version Lightburn-v1.7.06 and tried to run it. It doesn’t startup. So now I’m questioning my system updates.
OS Name: Microsoft Windows 11 Pro
Version: 10.0.22621 Build 22621
System Manufacturer: LENOVO
System Model: 21DJ
System Type: x64-based PC
Processor: 12th Gen Intel(R) Core™ i5-1235U, 1300 Mhz, 10 Core(s), 12 Logical Processor(s)
Unfortunately I have no choice but to load RD Works to get some work accomplished.
Here’s a link to send them an e-mail.
support@lightburnsoftware.com
Thank you.
In Microsoft, search for %temp% and %time%,erase everything that can be erased,reinstall Lightburn!
Thank you for the suggestion. Unfortunately I ran into issues with RD Works and the USB driver not wanting to connect to my Rudia controller. So last resort was to do a Windows restore to a point several days ago. It took an hour and now the latestest version of Lightburn is running fine. I’ve since turned off Windows automatic updates.
Or, better, follow the less-brutal recommendations generally leading to a resolution:
