LightBurn v2.0.00-RC-9 Release Candidate
I also noticed on glavo, in rotary mode:
Run whole Shapes if Possible: activated
Run Shapes in Shape Order: activated
–all fine
but:
Run All Shapes in Each Slice: activated
–some parts of the design are going out of place
termo.lbrn2 (77.5 KB)
On the right side where the windows can be tiled for laser art library etc ours will only open one at a time. My download to 2.0 made my icons HUGE! I got them smaller in the settings but the right side was still so big we couldn’t see the tabs at the bottom. We rest it and now only see whatever tab is open. How do you have yours where you can see your laser and the tabs? I’m sorry if this is garbage talk that makes no sense :slight_smile: I just saw your pic and I want the view I had before upgrading to 2.0
Sounds like you may be dealing with a Windows Scaling issue that has been reported. We are working on a resolution, due in a patch once we have a well tested fix. :slight_smile:
For now, this may help you:
At the begging of this post there is a compatibility paragraph: “2.0 will be the final release that supports macOS 11 — subsequent releases will require macOS 12 (and higher).” Does it mean minor version like 2.1 won’t be compatible or is it the next major version like 3.0 that will not be. Presently In my shop I am using an old Mac mini which is limited to OS 10, but also have in the shop an old iMac 27" retina that I could move to the laser but is limited to OS 11. In my office I am using a Mac running the current OS 15.5 where I mainly do all my designs (Ligthburn, Fusion360…) and then transfer the files for Ligthburn or my CNC to the shop computers and still want to do some modifications locally when needed. That is the reason that I want use the same Ligthburn version on the 2 computers. Before I move the computers around or buy another one, I would like to know if the OS11 compatibility is very short or at least one year.
Thank you.
