Release Candidate 4 of LightBurn 2.0.03 is now available here:
LightBurn-v2.0.03-RC-4 - Change Log
Changes Since LightBurn-v2.0.03-RC-3
Bug Fixes
- Fixed issue with docks resetting to default layout every time app is started.
- Fixed issue causing docks to consume entire window if operating system display scale is changed.
- Qt6 set a 256mb max image size. No thank you. (#1181)
- DEV-1881 Font skips around and reverts on Mac (#1147)
- Stop button didn’t properly reset spindle/laser state to off. (#1174)
- Updating the logic & text of the device size mismatch warning. (#1193)
Existing Feature Updates
- Move “library” buttons under the lib into a menu to allow shorter vertical (#1170)
Other Changes Since LightBurn-v2.0.02
Bug Fixes
- Changed single line font prefix to SLF, instead of SLF-
- Head mounted camera wizard AprilTag pattern was not working if device units were imperial
- Removing discrete jogging clamping, fixing continuous jog for G54-configured machines. (#1110)
- Fixed DPI scaling issue causing blurry / pixelated setting switches and list item icons when display scale is above 100%.
- Use error dialog in case of error reading controller info, use warning icon otherwise. (#1113)
- Relax distance requirements on Docking
- Extend Docking outside workspace, to fix rounding error bugs
- BSL ‘Done Marking’ signal wasn’t emitted (#1132)
- Intersection snaps fixed (#1128)
- Bundle Import from device window was broken (#1140)
- Empty shape could crash gcode generation (#1141)
- Fix synchronous-mode timing regression.
- MacOS rate limit for Ruida, + variable packet size limit
- Forcefully truncating float numeric error for position down to 1 micron.
- MacOS could hang or crash when framing (#1153)
- SVG ‘s’ command didn’t work for sequences of points (#1160)
- Fixed bug causing bottom of main window to appear off screen on load.
- Fixed incorrect maximum size limit on MacOS toolbar buttons.
- Fixed issue with toolbar icons having edges cut off.
- Fixed issue that could cause main window to load on incorrect screen, sometimes many times larger than the screen.
- Prevent top level menu keys from conflicting with hotkeys.
- Updating displayed position to 0,0 after homing on Ruida. (#1165)
User Interface Updates
- Dramatically improved quality of UI when High DPI scaling is enabled.
- Selected shape / item dash length now scaled for screen dpi.
- Better handling of Enter key in Repeat Marking (#1126)
- Don’t auto-weld single line fonts, only classify SLF-OPF as Single Line
Miscellaneous
- Update Darkly Labs links and logo
