hope this helps someone
LB recently added GRBL extra connection : ethernet/TCP
there is no settings that would allow the port changes.
LB has used the default TELNET’s port23 as the start point.
in order to change the port for MKS DLC32 to be able to connect via WIFI:
we would need to export the preference and modify the default port 23 to 8080
and LB it will be able to connect without issues.
