I’m experiencing an issue with LightBurn. A few days ago, it stopped working on my PC. The program seems to load, but the window doesn’t open. It was working perfectly fine just a couple of days ago, and I haven’t made any changes to my system—no Windows updates or anything like that.
I would prefer not to reinstall the software because I’m worried about losing my settings. Unfortunately, I haven’t created a backup, and since the program won’t open, I can’t create one now.
Here’s what I’ve already tried:
Looking for the running process in Task Manager and it is not listed
Holding the Shift key while starting to reset settings.
Restarting my computer.
My Questions:
Is there a way to back up my settings manually without opening the program?
I’ve read that settings are stored in a folder, but I’m not sure how to find it or secure them properly.
thank you gilaraujo for your workflow. I didn´t see it before. Now I have fixed the problem by myself. I wanted to share how I managed to fix the issue with LightBurn not starting while keeping my settings intact. Hopefully, this helps anyone facing a similar problem!
Here’s what worked for me:
Backup your settings:
Navigate to:
C:\Users<YourUsername>\AppData\Local\LightBurn
Make sure to enable hidden files to see this folder.
Copy and save the entire LightBurn folder as a backup.
Uninstall LightBurn:
Completely uninstall LightBurn from your system.
Go back to the above folder and delete the remaining files in C:\Users<YourUsername>\AppData\Local\LightBurn.
Install an older version:
I installed LightBurn v1.6.03, which you can download from the LightBurn website’s archive (if available).
Restore your settings:
After installation, paste your backed-up files back into the folder:
C:\Users\<YourUsername>\AppData\Local\LightBurn
Launch LightBurn
So I can work, since I try the other workflow. Thank you!
So, I tried the other workout and after installing the redistributables and update Lightburn again to 1.7, I can start the program. Thank you, for your help!
Buenos dias gilarajo, excelente, he realizado sus instrucciones y Eureka!, mi sofware lightburn 1.7.03 actualizado con licencia comprada se ha y abierto y así mismo recuperado…ggracias amigo …abrazos desde colombia
