I connected the laser to my PC with a USB cable from Lightburn with the “Find my laser” prompt. No luck, then I tried to do it manually and typed in the IP address for my PC and gave the laser a similar address and it still doesn’t connect. Please advise
You can not use the Find feature to set up over a network. For USB connection, you may need to load the driver found on the last page of the LightBurn installation. Run it again, advancing to that last page, install that driver, then try the Find again. Redirecting...
If you do want to connect via Ethernet, have a review of this post:
I messed with the USB game, finally just put it on the network and haven’t been happier. All of your symptoms indicate you’re missing drivers…
good luck.
