Need help. Since installing the last 2 Lightburn updates, Lightburn will not open to full screen, opens to small window, then I have to maximise. I am using a 16"Gigabyte Aero running Win 11.
I have made sure the properties is set to open maximised, I can force it to open maximised holding Shift key, but when I exit and open again, it opens in small window. I have tried closing Lightburn while holding control key, still opens small window next time.
Is this a problem only for me or are others experiencing it? Is there a fix (other than what I have already tried)?
Sorry, yes I should have said - this is only happening in Lightburn. Have a number of browsers, office programs and image editing programs all open full screen.
deleted files in pref folder, re-booted - still the same. Re-installed Lightburn again, changed properties to open maximised - still opens small window. Only way I can get it to open full screen is to hold shift key while double clicking desktop shortcut. If I close while holding either CVontrol or Shift, it doen’t remember window size and opens small again.
don’t have any machines connected to this laptop - this is for my design work. My other laptop hooked up to 2 lasers is working fine, though I haven’t installed the .02 update on that. It is running 1.5.01 with no problems. On this laptop I just set up a dummy machine 400 x 400 diode style, but I haven’t done that again yet since the updates.
funny enough, just for the sake of sanity check
Add manually a GRBL mahcine 400x 400
see if that triggers “something” that writes maybe some settings that enables window position to stick?
I can grab and drag put all 4 sides to increase the size of the Lightburn window - out to nearly full screen. But, once I close the program and re-start it is in small window again
In the freshly started small-screen state, in LightBurn, click File, click Export Prefs and save that file somewhere convenient.
Drag and drop that file into a reply here so I can take a look.
If you haven’t installed any new hardware recently, in LightBurn click File, and click Load Prefs Backup.
Pick a file with a date that corresponds to when the screen behavior was the way you wanted it.
LightBurn saves the last 50 versions of these files so you should have one that works. Jot down the name of the file. If the file works well for you then I’d like to compare it to the one with the small screen behavior.
