Limit of Ruida RDC 6442G
I try to engrave some images by grey scale with Darkline LC6090 with Ruida RDC 6442G-B controler.
Lightburn send file up to 1Mo.
The controleur respond by error message "pas assez de place " in french equivalent to “not enough room” ?? (room or memory ?).
Some images are engraved some any other can’t with the error message.
I reduced lightburn files to 100k, but the error stays.
Lightburn works as usual, and the controler is able to show frame area received, that could mean there is no error in lightburn data file sendt.
I think possible an internal error of post-traitment by controler,
but how to avoid it ?
Thanks for any proposal of test and/or traitment to grant this engraving.
Did you remove any files you don’t need from the Ruida memory?
Might want to read this thread… they talk about your issue…
Good luck
Thanks for yours information,
The problem was about physical space !!
In fact as i had strong speed (500mm/s), the machine request very large oversize vs real engraving area.
By heavy decreasing of speed (100mm/s) the machine valid the engraving file.
Great surprise about this conclusion, because engraving area is 1/3 of machine capability. but the result with lower speed was perfect …
Thanks for your help,
