LM2 Pro Move buttons don't work right when continuous jog is on
Mac Monterey 12.7.6
Lightburn 1.7.08
Ortur LM2 Pro
Home is lower left corner. And homing works fine
I’ve started seeing an odd behavior with the move buttons. When I turn on continuous jogging, the left and right move buttons only move up the x-axis (to the right from home) and the up and down buttons only move up the y-axes (towards the back). When I turn off $J, then the buttons work as expected.
When the laser is “home” (lower left corner) Lightburn reports the X position as -397 and the Y position as -397. Shouldn’t this be 0,0 (zero, zero)?
This is fairly new behavior.
I had just done some rotary chuck work (could that have “broken” something?)
I wanted to reinstall the firmware but when I drag the “Bin” file to the laser, the Mac disconnects.
Thanks.
Depends, but usually, yes. Enter $# in the console and check the output. Is everything set to zero there?
It’s possible to change this to 0,0 again. Just check your settings first.
