Longer Ray5 20w, Transfer Failed
Unable to send files to the Laser, longer ray 5 20w.
error: Transfer Failed, there was a problem sending date to the laser. The machine may be busy or paused.
Device is connected, and says laser ready.
in console, it has this listed: E (51) efuse: Range of date does not match the coding scheme
MSG: using machine: MKS DLC32
New laser machine has not been able to do anything.
uninstalled the program same error, using Windows 11.
Set up as instructed, GRBL
Sometimes, unplugging and replugging the USB cable can fix the issue, but it might also be due to a faulty cable.
The USB cables that come with lasers are often not of the best quality.
I’d recommend trying a better USB cable with a ferrite choke.
Here’s a similar post that was resolved by using a different USB cable.
HTH.
