Hi Lightburn laser wizards,
I am having serious problems with my new xtool D1. Below is a copy of what I sent xTool tech support, but essentially, when the laser FAST travels between shapes I will hear an angry noise from the stepper motor and it will print 3-6 mm off of alignment from then on.
I am trying running to 80% of max speed with “motion limit” on to mitigate but it still happens once per hour sometimes.
I’m glad I’m configuring with inexpensive materials, would LOVE any tips!
------------------------------- Copy of my e-mail to support@xtool.com ------------------------
Hello,
I have gone through all the faqs, manuals and troubleshooting thoroughly.
My new xTool D1 is losing X axis alignment during fast travels between shapes.
I have new firmware,
I am using lightburn
Belt tension seams fine, i think
machine and travel squared beautifully
rails are clean
it’s brand new, 3 days out of box
I feel like if I could change “machine settings” → “X Acceleration” it would probably fix this, but I can’t get settings to write in firmware.
Lightburn says it writes to hardware successfully, but when I read them back they are always default. Have tried moving firmware lock switch to both positions.
I’m sure it should work with the default travel settings, so I am hoping I don’t have a broken machine. I can only find settings to speed up travel, not anything to slow it down! (other than those controller settings that i can’t get to write)
Essentially, when the laser FAST travels between shapes I will hear an angry noise from the stepper motor and it will print 3-6 mm off of alignment from then on.
This happens repeatedly even after slowing to 80mm/sec.
Thank you for your time, let me know if I need to clarify my question
